Hi again folks...well after this problem reoccurred a mere 10k miles after the first pinholes were detected in the covo. tube inside the tank, Ive decided to tacke it myself...i bought new clamps for the tube and jokenly said to the parts cointer guy, 'ha, you dont need a special tool for them do you ?' Of course you do...so my question is ...can I just use a set of screw type clamps or will that for some reason not work
After the third time I had to replace them on my '03 UC, I had enough!! I put some heavy reinforced fuel injection tubing in there instead, and have never looked back. Yes, I used worm-gear clamps.
BTW, change out the fuel filter and fuel pressure regulator while you have all that stuff out of the tank if you did not do it last time.
