Iceman24
Well-Known Member
I've run both on my 09 FLHX and you'll discover the difference w/1st post-install start-up. Bike will feel & sound better, and all you have to do is adjust for your stock tune. Otherwise the MPG's will dip a bit. I found gas tank removal the easiest for install b/c it allows free access to injector(s) and no restrictions w/cable routing. There's a plastic backbone that runs on upper frame tube with plastic cups along Right side...perfect for the tuner lines. Also, Dobeck's support is 2nd to none so cal them if you need any assistance. Enjoy!
