mnultra
I have to disagree a bit with some of the previous comments. The Fuelpak is really easy to install, ..just plug and play..the O2 sensors don't have to be unplugged..all you do is plug the Fuelpack into the ECM, punch in the numbers provided with the Fuelpack and you're done. Also, Vand H provide the settings for a number of aftermarket exhaust systems other than Vance and Hines. And, if the exhaust system you want to use isn't included in their list, all you have to do is shoot them an email, tell them what you want to use and they'll email the settings back...simple. Now, if you plan on making changes to your bike other than a stage 1, the TFI would be the way to go. So, for a stage 1 upgrade only, the Fuelpak is the simplest and easiest. Oyher that that...a TFI is your best bet.
Couldn't agree more Subby. I love my fuelpak and will put one on my next ride as well. Everyone talks about being able to adjust the TFI, which is spot on, but with the map provided from V&H for my set up, I didn't have to adjust a thing and I am very happy with the performance of the unit. V&H hit it spot on. I didn't want to mess with "pot" settings, taking the bike out for a ride and readjusting, messing with the injector harness or running wires neatly from the injectors to the unit. It really can't get easier than installing the Fuelpak. JMHO
