Don't feel bad, even the simplist things can be a hassle...I was changing the air filter...problem is it was a no name type so no instructions, but only 3 Allen screws...how hard can it be? H-u-m-m-m English or Metric...
Find out it had not been changed in probably years...they are frozen on u-g-h-h, finally broke them loose, no lube on the threads, steel on aluminium not good; backed out the cover with the screws, Clink, clink, clink; three 3 spacers fell to the bottom of the housing (lucky they did not fall into the carb throat or worse), look at that dirty cheap paper element, gas & oil saturated without any metal form to stiffen it (you could move it around in the housing like putty).
Oh Boy, the real trick, putting it all back together without the spacers falling out (used assembly contact cement to attach the spacers to the mounting studs) good enough to start all 3 screws without chasing loose hardware, evenly hold cover and new filter aligned (look MA, I need only two hands for...:newsmile030:...
UH-OH...WAIT how do I stoop down, hold the flashlight to line up the holes to start all three screws, hold the cover, keep the filter straight and button this silly thing together? A-R-G-H-H ...HEY I ... GOT IT! :newsmile058:
Honestly, even though it was more time and trouble than I thought, the satisfaction of doing it myself, learning how to do it correctly (although by trial and error) is a very good feeling. Yes, I will change it more often and do it right...Time for a cold one....:cheers
