Take a look here for testing your coil.
If you want to "bench" test a coil, remove wires, attach a hot 12 volt to the battery (batt, +, etc.) terminal. Then attach a wire to the ignition (ign) terminal and touch ground and remove. Should throw a spark from the high tension lead with each application of 12v and removal. The ground wire basically imitates the function of the ignition points/module. If the high tension lead terminal is gapped a reasonable amount from the engine, there should be a bright white spark. Weak or orange spark indicates (low voltage...or) bad coil output.
