Ok, I know this thread is old, but I'm new around here and I find this thread to be important.
That this procedure makes a bike run better immediately is no surprise; it forces a tight new engine to loosen up very quickly.
It does not necessarily mean that the engine becomes more powerful, only that it does it quicker. It certainly does not mean that it makes the engine last longer. I've read MotoMan's arguments, and I am sure he’s right when it comes to the rings - a 'normal' break-in does include the risk of not seating the piston rings fully. His point that deceleration as part of break-in improves the ring seal is probably also valid.
What I do not agree with is his claims that with modern day fine materials and tolerance machining, normal break-in is not needed (just ride it hard!): Either the engine is perfect, or so much out of tolerances that it is beyond any hope  - do you really think these are the only two options?
I don't know how Harley does its engine assembly - probably part robots, part manual. Regardless, the left and right cases are just a normal, bolted connection (i.e. no interference fit), to match internal tolerances of two thousands'. Think about it - the bolting together means that the crankshaft will not sit perfectly straight relative to the bearing surfaces. The inherent variations in the assembly process coupled with production tolerances is the reason why all engine manufacturers recommend the same principles of engine break in: you could have an engine with most internal tolerances at max positive or negative clearance, angle, offset, or any combination of these – no one on this planet knows how YOUR engine is. (This is what ‘blue-printing’ an engine is all about, or what the serious standard production bike racing guys do – optimizing tolerances)
Even a robotic arm accuracy tolerances exceed the pinion bearing tolerances by far to start off with, getting worn over time...
This is normal and not dramatic, but it means that the parts need to get acquainted before receiving max load, unless you just bought the perfect one. Do you feel lucky?
I did not see any main bearings, crankshafts, connecting rods/bearings in the ‘museum’ but it would not bring anything to the table even if it did.
My point is: The normal method of breaking in an engine is a trade-off between getting all internals to work together nice and easy at the limited risk of not seating the rings fully. What would you rather replace, your piston rings or a main bearing?
I do not call MotoMan a bluff.  As many of you know; race engines are built loose, while a daily rider should be tight. It is all about power and immediate readiness vs. longevity, which a race engine does not need being torn apart after every race.
30-60-30x10 fit for purpose? Yes, for race engines.
A combination of the two methods would be ideal...
