If it is single fire-both spark plugs fire at the same time-you will have one coil. It it is duel fire-the spark plugs will fire seperatly-and you will have two seperate coils.
Isn't it the other way around?![]()
why don't you check the plugs for spark and while they are out check the compression of the cylinders. Also check that the manifold is aligned and sealed.
SINGLE FIRE = both plugs fire individually, not together but there is a single coil
DOUBLE FIRE = both plugs fire at the same time and there's two coils.
Single Fire = both plugs fire individually, two coils
Double Fire = both plugs fire at same time, one coil
It depends. As far as the coil goes, you can have 1 physical coil which contains 2 indendent electrical coils (2 primary, 2 secondary, 2 towers). You also can have 1 physical coil with 2 secondary towers, 1 secondary winding with 1 primary winding. Or you can have 2 physical coils, EACH with a single primary winding, single secondary winding and 1 tower.
That is why I asked how many primary terminals there were on your coil.
Jack, I hope that's not true because I make up alot of this stuff!..
Your link really tells it all.... Great link.
