G glider Veteran Member Apr 12, 2010 #11 Turk55 said: Allriddie then, its 3.5 full hot on mt SG, that is unless you are able to get all the oil out, then its 4qt by the book. :cheers Click to expand... Dry fill is 4 qts otherwise it will be overfull with a wet fill.
ironmark Junior Member Apr 12, 2010 #12 I put in 3-1/4 qts in mine any more oil than that & the oil will start spitting out of the air filter .
