mgierman39
Why dont you pull the outer primary off maybe pull the drive chain, clean everything off. start the bike and let the motor warm up and run up the rpm a few times and check for leaks. Dont run it to long and over heat the motor. Maybe run a couple fans on it to help keep it cooler longer. Let the bike cool down and repeat. Have a cooler of brews ready and make an afternoon of it.
Do you have oil pressure on the return line? Clogged return line? Is the oil pump faulty and not pushing oil back fast enough into the the tank so the bike is sumping like it would sitting for long periods causing a back pressure?
