BUBBIE
Well-Known Member
Just curious Bubbie, why Kirby for the cylinders and not the heads or vice verse?
I KNOW they Both do good work.
Don Dorfman lived about 30 minutes away from me up in Wa.
I never met him in person, Just on the forums of which he is a member.
My wife and I met his wife by Freaky conversation about bikes at a fast food place... We were on my bike and she said My Husband and I ride also...
She Mention her husband Don,,,,,,,The I said Dorfman? YES she surprisingly said......and then we went into conversation... Don and I knew each other but not in person. I did plan Long ago that He would do my heads.
I had him sell me a set of 08 pristine heads to work with. PR's and also drill and tap the threads needed for the King on the front head.
Long ago, I talked to Don on the phone a few times and wanted to see his shop up in Edgewood Wa. (20/30 min. away) I was passing close one day and called him, he said to just drop by and his wife would be there to Talk and show the shop.
I was VERY impressed with his shop and tools. I never got the heads done Until later as I was Down here in Az. (both places lived)
He had Bought the business fro Dewey's Heads some time back and has come Leaps and Bounds furthering the Designs and his ability (superior) to many others. Don ranks High and so does Kirby...
Now Kirby prodrag1320, was After I made arrangements for the Heads and got them IN... Not sure How I was going to get the cylinders done ? send in My cylinder or Buy a set of used and have them done. The Latter is what I did.
Sending Kirby the Seasoned cylinders, Rings, SE Pistons, for the bore and final fitting, he did all...
That Boring to fit properly is Very Important as the Small 103" Tuna Cans have problems IF too loosely fitted, they want to turn Sideways and then you have Piston Slap... Knowing from others that Kirby is the man. !!!
Knowing Both do BOTH I would have NO Problem having Either one do my work.
Okay-dokey?
I have Steered Clear of the Build you can buy ready to go... I've been BURNT before Buying KITS as parts were just tossed together off the shelf and NOT fitted like I wanted My Job...
Quite frankly IF it cost a little more to get it done BY THE BEST and Peace-meal it...NO Problem in my book... This is one reason MY build runs so good. Only the best did the work...
