Again Thanks for all the tips and advice. I did some checking and removed the plugs and made sure there was no excess condensation anywhere, wiring and other electrical areas per 2 of the dealers I talked with. I did notice a discoloration in one of the plugs (front jug) and the other look normal. Cleaned it and put some RemOil, that someone recommended, (top cylinder lube) in the cylinder. Didn't start her up cause it was below zero outside, not much better in my garage. I have stabilized the fuel, set the battery tender and will wait until March. My dealer did not play down the a possible crank problem, but suggested that I bring it when possible and they would check it. They want to road test it to check, but in Maine that won;t be until late March, early April anyway. I'll bind my time for now and I'll keep learning stuff. Thanks
