free website stats program Evo 1340 Help | Page 3 | Harley Davidson Forums
Evo 1340 Help
Thanks you two for the Air Cleaner links. I am needing to replace the current air cover insert; thing is- the Mikuni/ Rev Tech model uses three push-in clips/fasteners to hold the insert into the cleaner while others use a set screw. This is where I am having a hard time finding an aftermarket insert.
EDIT: If I cannot locate one; then I am just going to have to replace the whole air cleaner. Kind of embarrassing rolling around with a Rev Tech 100 badge. LOL.
You know it might not be a bad idea just to cut the line going from the drain tank to the oil pump, put a "T" connector on it, then like a 1" piece of hose going straight down with a magnetic plug on it... I just like magnetic plugs maybe, i always have one on my oil drain... It never picks up anything much, but i like having it there for a warning sign.
