If you drained the oil and changed the filter before you started it, all the old oil would be in the bottom of the engine and you wouldn't have drained much oil out of the tank. I'll bet you have way too much oil in there now and it's blowing out the carb. You should run the bike awhile and then drain the oil, better yet, take it for a ride and warm the oil up and then drain the oil.
