J
Jack Klarich
Guest
Time out.
If the clamp is a TORCA clamp, this clamp need to be flush with the end of the slip over pipe section covering the slots in the pipe. As you tighten the TORCA it will compress the two "halves" of the over-pipe securing the pipe and sealing the slots. If the TORCA is too far back over the solid part of the pipe, it will be ineffective. Check that first.
T Q I think the OP is talking about the smaller cross over between the front and rear exhaust pipes, it is a cheap set up, and a bit of high temp silicone or copper grease as Brian says will seal it, I have done newer Sportsters and Dynas that leak here like this Just my 2 cents worth:s
