black02flht
I pulled off all the old exhaust without any issues.
Question: Is is better to use the the stock exhaust gaskets or the screaming eagle exhaust gaskets?
When I started to put the stock exhaust on I noticed that the bracket for the rear header was not quite right. Later I discovered that it was a different bracket for the true duel setup. So I have the stock one on order. Are there any other things that would be different using true duels that I need to locate such that I can get back to the stock setup. The bike came with the true duels I did not put them on.
Thanks,
David
Thanks,
David
