An se back plate is a better idea than drilling the stock back plate however when I did the drilling I did not have an se back plate to hand and parts can take up to 3 months to get to me so it was a temporary stop gap
At the time I had suffered a lot from carb icing and had purchased a mikuni hsr carb kit that should have come with a air cleaner cover with a cut out at the bottom to allow for more air
I did want to draw warm air from the engine to try and overcome the icing however the mikuni throat does not compress the air as much as the stock cv therefore the air does not get so cold so the jets do not get cold enough to freeze the moisture in the air
