BUBBIE
Well-Known Member
ON MY 2009 FLHR,
ONE TIME I OVER FILLED gas tank AND found the next morning that the GAS GAUGE-BASE popped out..... STUCK UP LOOSE... I had to reset it BACK, INTO the tank..... GARAGE smelled of gas was how I first noticed it...
MAKE sure the gauge is seated all the way into the tank.... PUSHING straight into it...I think it only fits in one way...IT reset easily and I have never had a problem since...
THE GUAGE (cap) and PUMP is needed to FIT ALL the way INTO tank,,, close to FLUSH,,,, I think this could be your STARTING PROBLEM and the FIX is above........
dont see how the fuel guage can change anything, the guage goes into a cup welded into the tank, and a tube goes down and out the bottom of the tank for the wiring.
PART OF HIS QUESTION WAS """" STRONG SMELL OF FUEL IN GARAGE""""
If you RE-READ his starting question !!!!
THERE is MORE to the UNDER THE CAP FUEL GUAGE THAN A ""COUPLE OF WIRES"" on MY 09 FLHR
I can't tell from HERE what HE meant by STICKS UP ABOVE THE TANK OR NOT FLUSH ENOUGH...
MY STATEMENT WAS FROM what happened on MY BIKE and thought it may be HELPFUL to OTHERS OUT THERE ......IF it happened to THEM.
I surly had this problem and STRONG GAS SMELL in garage was the CLUE!
