I strongly agree with always riding within your skills plus the bikes limits, and practicing to ensure you are exactly aware where both reside. Practice was one important item I neglected to do before setting out on my carving mission.
The point of my posting was questioning a popular modification that potentially could negatively affect the bikes cornering limits. In my opinion reducing your riding limits to compensate for a modification is not an acceptable resolution.
One thing that is key to all this is learning to "counterlean" the bike so that you put pressure on the outside peg but center your body to the inside of the bike...in essence standing the bike up while your body compensates being in the inside of the turn. This is a common racer trick to compensate for limited ground clearance, or bumpy turns, especially off camber turns that initiate hard contact, that could unweight one or both tires tossing rider and bike off the road.
Practice doing this "hanging off" on that same cloverleaf you had the problem with (the bike standing up 10 to 15 degrees more vertical equates to almost an inch of additional ground clearance) more than enough, even with some mid corner bumps thrown in...
