dolt
Well-Known Member
there is a vid on youtube which is cannot get (at work) that shows how much the valve springs move on the stock heads its scary, mine have stronger springs as a precaution and i am running much higher comp than most street builds, i am at 10.6 corrected and as you know i ride a tlot harder than most, so yes a normal riding and hitting limiter everyso often will not be an issue but when your running 6500+ daily it dont do em much good
and yes i really do ride this hard i barely use 6th on the mways and do not use 5th/6th when on the back roads i rarely get out of 3rd
Seen plenty of videos but none that show erratic valve spring behavior in a Twin Cam at 6200rpms. I just had a problem with such a general statement that indicates that the stock valve train is weak; it's not that bad.
JMHO but I wouldn't build any engine for myself for the street or touring with a corrected CR above 9.5. Most, not all, 95" builds rarely exceed 9.0 corrected CR and the stock springs are up to that task. Once the corrected CR is > than 9.0, more spring pressure should be considered depending on the cam choice.
I am not challenging what works for your riding style but just wanted to make the case for the stock beehive valve springs; they are actually pretty good hardware. They will hold up in a stock application as well as most 95" or 103" big bore upgrades.
