What would that switch do that going from high to low and back wouldn't do?
hey dangerdan thanks for the info. actually i do just want a momentary switch that i can control myself. so i can "flash" cagers at will. i too hate the flashing headlights that are on all the time. i want to put the switch on the switch housing behind the clutch lever. so i can flash with my finger. as far as the wiring, do i just tap into the hot wire off the headlight to the switch and ground the other wire? just want to be sure. thanks again.
You will just need to use the switch as a break in the wire. The same wire connected to both sides of the switch with the switch in between.
Should there not be a fuse in line here just because?
It would actually turn OFF the light by disconnecting the power source as opposed to switching it from high to low beam.
The fuse is already supplied within the factory wiring and would still be effective to protect the system but if one is inclined it could not hurt
got an 09 RKC. i want to hook up a momentary switch to flash the headlights. i don't want to mess it up. diagrams anyone? thanks
