free website stats program Fluid change update at 39k miles | Page 2 | Harley Davidson Forums
Very good test results and thank you for sharing this information. The use of double platinum plugs is an interesting and I noticed right away when I opened the pix. Platnum plugs do seem to be more durable...wear is very low, so gapping is not necessary as usually for the life of the plug (they are the plugs that are said to last up to "100,000" miles)...hmmm! :34:
your oil "break down point" is way below 385dg syn or dino or a mix in your case dino breaks down around 250 syn around 300 now i'm not %100 sure about the breakdown points but think i'm pretty close. if your oil gets too 385dg you will need a new engine lol and u may have burns on ur legs from the heat coming off the engine
