glider - I boiled the dipstick in water - I assume, about 212 degs. and the dipstick temp gage showed 210 degs. So, it appears to me that the dipstick gage is pretty accurate. At least close enough - which would tend to indicate my engine oil temps are running about 200 degrees. That day I rode, 2 up (wife) the ambient temp - south Louisiana - was about 70 degrees and I was riding between 40-60 mph - put a total of about 80 miles on with about 40 or so just before stopping at home and checking the oil levels. I think I just need to change out the engine oil and re-check it all over again - cold and hot.
It may be (and I hope so) that I just simply checked the oil too soon after stopping the bike at home. I killed the bike -- got off - looked around ~ 15 seconds for a shop towel - then checked the oil level. Basically, stopped the engine and immediately checked the oil level and couldn't get a good reading on the dipstick - looked inside and saw the foam.
Bill
You will be surprised how long it takes to raise the whole volume of oil in the tank up to operating temperature. If I read your note above correctly, the last outing was a total of 80 miles, with the last stretch being only 40 miles from last engine start. If this was mostly highway or at least fairly constant speed stretches rather than stop and go, 40 miles is not very far. Often when I ride to and from work (50% highway, 50% surface roads), my engine oil temp gauge breaks over the lowest mark about half way to my destination, and is only in the 170-180* range by the time I get home (or to work). That is about 25 miles. So getting to 200* as a final temp level could be about right.
But your comments about the engine oil condition are troubling. I would suggest changing it yourself right away. Whether you pick dino or synthetic is not as significant as KNOWING what is in there and its condition.
I personally prefer the synthetics in my bike (not the primary though!). I bought the bike used with 43,448 miles on the clock. I changed the oil and filter about 4 times using HD dino and HD filter, and at 58,108 went to full synthetic Mobil 1 Vtwin 20W50.
Glider is right that the synthetics, with their additive packages, do a better job of cleaning up the oil system, but in my case, I did not develop any leaks. The main reason I switched was that I had a cam chain tensioner nuke and wanted better lubrication and lower temp.
I now have 76k+ miles on the bike. I do not have any leaks that I would blame on the synthetic engine oil. But I have swapped out the tranny for an SE 6-spd and done the roller chain conversion, so it is really not an apples to apples comparison with someone that has only changed oils.
Which ever way you go, use the "recommended" oil change miles figure as a MAXIMUM. Use your riding conditions and the stress that puts on the oil to adjust DOWN from that maximum. Many of us suggest changing oil about 2,500-3,000 miles or every 6 mos. Since you are in S. LA, you will likely be riding all year, so you will probably not be "putting the bike" away for an extended down period. Always a good idea to err on the side of changing the oil too often then not often enough, IMHO.
