well, after some research and alot of good thoughts from yall guys, I believe the way to eliminate the hand brake lever and clutch lever is to use a proportional valve on a dual master cylinder as Glider has pointed out, and use a Left hand twist grip on the handle bars for the clutch. Exile Cycles happens to make a left twist grip already that has a hidden cable that runs inside the bars that they now use on clutches to clean up the bars on some of the bikes they build. That would solve the problem of stopping on an incline and rolling back. I think that if one wanted a suicide clutch and jockey shift the left twist grip could be used to work the front brake if you scratched your head and thought about it awhile. Thanks guys!
