cmvsm
I get my J&S jack this week... I have a couple of things on my list, one of which is to change out the fork oil, as I get kind of an odd ride when taking a rough corner. Thought this might help a bit. I also thought I might as well change the springs out to Progressive while I'm in there. Have almost 28K miles.
Couple of questions. What is the size of socket that I will need...is it 35mm? I've heard a couple of different sizes and wanted to make sure I order the right size. Also, according to the service manual, changing the fork oil is as simple as elevating the bike, popping off the caps, draining the oil, pumping a few times, continue to drain the oil, replace with new oil, and reinstall the caps. Is replacing the springs as simple as removing the old spring and replacing with the new one once the caps are off, or is it more involved? My service manual covers removal of the forks, but not the springs specifically.
Any comments would be appreciated. Thanks.
