J
Jack Klarich
Guest
Hoop, you are correct, I was incomplete in that this is the video to show how you access the top to remove the springs and spacer so you have a straight shot at the fluid below ONLY. The drains are on the lower forks, and use what looks like a Phillips screw BUT it has a dimple on it indicating it is METRIC...here is where you use a hand impact tool, but only for the tight fitting bit and large handgripping surface to remove it without drama. Drain in a measuring cup, noting that it should be around 11oz. Use new fastener plug (just my way cause I prefer stainless steel and Allen head). I use Bel Ray, 7.5Wt (stock is 5Wt) cause I like the ride soft like stock, maybe a little bit stiffer, reassemble and repeat for the other side. Sorry, as I feel the removal of the top stanchion cap is the "trickiest" deal of the whole operation.![]()
New Dynas do not have drain screws in the lower legs, The top caps have to come off to suck the oil out, Capital Jack
