Hoople ->{{If your measuring starter current draw, the shunt is not large enough. But if your wanting to measure the total running current of the bike or the output of the charging system you will be fine with a 50 amp shunt. That is because the starter motor current will not be going through it. }}
Ok good.
Hoople->{{ Does the starter motor current go through the Maxi fuse? No it does not. So if you insert the shunt at the Maxi fuse (or at the voltage regulator output), will the starter motor current go through the shunt? Once again, no it will not.}}
Ok good again, only I thought in your later post you said the Maxi Link would not work due to the way the bike was wired, (sketch 1, post #28) but I probably misunderstood that also.
Hoople->{{inserting this shunt directly at the battery terminal? No, that will not work. Besides the reading will be meaningless. Your going to be reading the differential amount current between what is required by the bike, minus the charging current. A somewhat useless number.}}
Exactly ( I see now, before I did not), only I now would have guessed it to be reading the charging current actually going into the lesser resistance (lower voltage) of the battery, but maybe that's what you just said and I failed to grasp it again.
I think you are finally teaching me this. I know you will be glad to be done with me. But I will be even more glad if I can learn it enough to boost up my troubleshooting skills on my vehicles. Will have to buy you some beer someday to pay you back for all the head scratching you did at my crude descriptions. Ha I can hear Bodeen now, there he goes again promising beer that never materializes.
But aside from my crazy backwards analytic brain, I have a good understanding of basic electric, it's just the ramifications of line current reactions that I've never gotten fully under yet. I do appreciate all the help.
Now before you go would you also please verify that I have the calculation assumtions correct to actually use this shunt (in the correct ) location.
I am understanding this shunt is designed such that the voltage drop across it, is Xv value of milliVolts when the current flowing through it is Xa value of Amps.
Therefore I can calculate the 'design' Xo value of ohms resistance of this shunt to be design voltage Xv divided by design current Xa. Correct ?
So then = Xv / Xa = Xo design ohms
Therefore if doing an incircuit test a voltage drop of say 28mV is measured across the shunt using a standard multimeter, I can use a ratio math calculation so that the 0.028mV / Xo (design ohms) = Test Scenario Amps. Correct ?
And further I suspect that overheating could damage this shunt. Should I attempt to never measure more than WHAT ? percentage of amps of it's rated 50 amps ?
Thanks again.
