eleft36
Junior Member
I cut 3 good size oil grooves in my SE compensator about 6K miles ago. Pulled it apart just to check on how it was doing. There was plenty of new fret rust. The grooves seemed to not help at all. Formula + oil was used.
Back trying another new idea.
Cutting down the fiber thrust washer to match the face diameter of the sprocket and machining angled scoops in the sprocket retainer to rout some of the lube being cast off centrifugally to the groves is an idea. The last time I changed the Primary oil I didn't see any red. Also when I modified the sprocket retainer I polished the rough cam surfaces with a small drum sander. So far it's not giving me a problem.
Al
:USA
:CONNECTICUT
