gator508
Experienced Member
One "little" thing, there is a small copper spring wedge that pushes the switch away from the housing to allow the switch "nib" to contact the lever. Don't ask how easy it is too lose that wedge, so the switch sinks away from the lever...and no more brake light actuation. If you open up the switch control housing, you just might find that copper wedge sitting in the bottom...or on the floor in your garage, and it is NOT magnetic, so don't bother using a magnet pickup tool...
Another little thing, be sure you do not pinch any of the wiring when reassembling the housings, may cause a short, I found out the hard way. Good luck!
