2003sporty
The fluid is new dot 5 which is purple so when the mc is full cant see the bottom of the reservoir - I've bled the system from the top to the bleeder and from the bleeder back to the top via a syringe and plastic hose plus have tied the lever to the bars and left that way over time.  Still with everything new and bled if you pump the lever quickly it will build pressure and the brake will grab and slow the bike however when the lever is released you have to start all over again - quickly pumping the lever to build pressure.
It was originally a single disc and has the 9/16 MC
