thanks! wiped fittings down first thing today with paper towel, nothing there..
i wonder if i have discovered an error in the service manual(and the instructions that came with front caliper kit)..under caliper reassembly it says to put a bridge bolt in the middle hole, and one by the bleeder valve, which is at the upper end of the caliper, so it will catch the air.. problem is the upper(long) mounting bolt actually seems to be the third bridge bolt holding the halves together, meaning the two bridge bolts gotta go in the middle and bottom hole(by the banjo bolt ). if you put the bridge bolts as instructed, the best way i can describe it when you go to attach the caliper to the fork, you will look at it like a cow looks at a new fence..
