J
Jack Klarich
Guest
Re: Top plate fuel leak
Either torque prevailing screws or The MOCO doesnt want a DOT problem with screw loosening up on a critical area like this. I can remember when they got sued in the early 80s for a defective gas cap JMO, Jack
I noted you said you used New screws during re-assembly. Sure enough the service manual says to be sure to use NEW screws.
What is special about using new screws? I can see a new gasket but why the screws? Can't use sealant around threads?
Anyone know?
