BUBBIE
Well-Known Member
Running high test premium fuel means that the ion-sense knock retard feature is probably not kicking in and retarding your spark advance which would hurt your fuel mileage.
Just curious,, what's your average altitude where you ride. The Switchback is a 103 correct?
Reason I asked about the factory download was because I have seen a dealership download the incorrect stage 1 map to a new bike. Friend of mine that has a 103" had a stage 1 map downloaded to the bike that was actually for a 96". I would have thought the ECM would reject it but it didn't. The maps were correct but the VE was adjusted for 7 cu/in less.
Just my opinion but I just don't see a tuner improving the fuel mileage on a bike that does not have some type of pre-existing issue. Even if changing fuel pot settings was to "correct" a problem, you would still have an underlying issue that was just being masked or hidden by the tuner.
Good one Hoople...
I wonder IF taking the ground wire OFF (Loose) on the Dobeck tuner to see What the mileage is when HD is fully in-charge.?
Then you have a base level to look at.
