Black07Roadking
I'm getting about 40 mpg... wish it were better!
2007 Black FLHR
SE/AC
Rinehart TD
PCIII
2007 Black FLHR
SE/AC
Rinehart TD
PCIII
Oh yeah I also lower the engine temp. alarm to 290 to make sure the motor wasn't gonna run too hot at that ratio, and when I check the warranty info on the tuner it tells me how many times I hit what temps. and it's only hit 280 a couple of times, and I think that was sitting at lights for a long time. It seems to run 250-260 most of the time.
You might want to think about an oil cooler if you don't already have one. Probably drop your temps by 15-25 degF. The Jagg 10 row is an easy install. I got the adapter with the thermostat in it, but probably did not need to.
I was talkin' engine temp. not oil temp. The oil temp on the dip stick runs about 220 and I've never seen it go over 250 even sitting at a light in 95 deg. weather. I've thought about putting an oil cooler on and if I do I'll prolly do it this winter. Our Hot season only lasts a couple of months over here and I think it's about done now.........only got up to 78 today. I'll look into the the Jagg, thanks for the tip.:cheers:rider
