Poser
If the problem is sensitive to the amount of gas in the tank it points directly to a leak in the fuel lines. When the leak is above the fuel level in the tank the pump looses pressure and starts pumping to regain pressure. I would start by replacing the fuel lines and fuel filter too to eliminate that as a cause.
If the problem remains then it is likely the pump - but to my way of thing the money was well spent on the fuel lines and filter on an eleven year old bike.
