maine-e-axe
Junior Member
Check the O ring on the cap you have on it or try the stock OEM cap to see if it leaks:57:
NOT the place you want wet with gasoline....ESPECIALLY if you're a smoker!![]()
I had the same problem with an 08 Heritage - stock gas cap. After I filled up I would tighten it until it started clicking. Turns out it wasn't fully seated. I know turn until it clicks, then press down on it and turn some more - it always tightens up a bit more. Haven't had a problem since.
Mine didn't start leaking until I was moving - and it didn't drip on the engine - it ran back the tank and got on my pants...
I had this problem with a set of gas caps I purchased from J&P.The O ring swelled slightly and allowed gas to leek when full.I swapped the O rings out from the stock caps and it fixed the problem.
