BUBBIE
Well-Known Member
I usually use mid grade or high grade. Very seldome do I use the low grade. I have noticed that when I do use the low grade there is knocking-pinging in the engine. Especally when the air temp is hot.
FUEL FOR THE FIRE!!!!
If you hear a ping or a Knock , you may be doing damage to a harley motor...
Ion sensor or Not,,, 91 or better is needed on fuel.(.) and for the added $ for it is worth the price.
Have You checked Your build date on the 2000 bike???
If it is a dec. 15,1999 build date IT Has the cam drive bearing that can go POOF.... Locate date and see on the front down tube is a sticker with the build date..... Let me know Just out of curiosity please
thanks
