RibEye
Senior Member
I suggest that you double-check your fuses. I seem to remember that in some cases those 2 sensors share a common supply voltage rail. Also, check the connections to those sensors at the throttle-body. Maybe they got diddled when installing the injector connectors.Thanks Dr. I cleared the codes now Im getting the codes P0107 Map Sensor Open/Low and P0113I AT Voltage Open/High. Which are codes I was getting before along with others now these are the only ones showing up. when I hold in the reset button on these codes until clear comes up do I press and hold again, which is what I did, and if so does it say anything so I'd know it was cleared? Also what are these codes for?
Just thinking out loud...
Enjoy,
Rich P
