Currently I have a little velcro patch on the left heat shield that my controller sticks to when I use it. Convenient to use but I am also considering mounting one of the permanent/surface type somewhere instead....I would most like it up on the fairing somewhere to see it and adjust it easily, just havent figured it all out yet...
Phil
When you say "heat shield" you are talking about the plastic/leather ones that keep you legs cooler, from the radiant exhaust heat, that mount under your seat. Correct?
I also had the portable dual controller and found it difficult to use. I didnt have a good spot to mount it, so I zip tied it to the crash bar on the saddlebag. The biggest problem was I couldnt see it. I took the fairing apart and found that I could mount the permanent control knobs near the tach and speedo so I went and ordered the permanent controller. I just recieved it today and plan on installing it this weekend if I get time.
Great! Please let me know how it works out. Photos would be great is you can take some.
Right now I am thinking of two options before I order the permanant mount:
1.) I was looking at the left handle bar and thinking about mounting my current, portable controller there, inside of the clutch lever mount. I can run power under the tank, along the frame and have it come out up along the handle bar. I think I would eventually have to cut/splice the wires for a more custom fit as far as plugging in the garments. But this would leave the contoller in a good spot, right by the grip and you would only have the two "plug in" leads for the clothing popping up right at the nose of you seat (or something like that). For all this trouble, the permanant mount makes more sense but I think that the position of the controller knobs is really good here. It doesn't address removing the contoller for washing or taking it down in the summer. This is where I wish Gerbing made a "clampable" waterproof, exterior handlebar controler with some long leads.
2.) Trying to figure our a mounting solution for the area right at the nose of my seat/CB-intercom. Velcro might work there but I would like a more secure solution. I don't remember what is under that black console on top of my tank and if I could drill some holes in it. Up closer to the gas cap would be ideal, I think, to make temperature adjustments.
If those don't work or I don't like the look/functionality, I think I will go with the permanant mount that you are installing.
