Porter
Junior Member
Here is what I decided to try. It is made from a 1/2" wide piece of stainless steel. I bent it around a 1" x 1/2" piece of solid bar stock. The fasteners are stainless. Locknut and a washer on the back side. Between the mounting bracket and the plastic is a small piece of EPDM rubber (adhesive backed) that I cut to shape. The lid of the gas cap has a about 1/2" of space from the top of the knobs, in the open position and the hand grips have about the same, lock to lock.
I can use the portable dual controller like this when it is in the case with the belt clip. I can easily take it with me and if the dual controller ever fails, it will be very easy to replace. It is easy to get to the knobs now while riding and I can do it without looking down. I will polish the SS bracket to a mirror finish later, to match the chrome. I also plan to make a plastic "clip" from some Kydex to add some thickness to the SS portion where the belt clip attaches. This will make it a little more snug and reduce any wear from vibration (SS on the belt clip). It will just pop on and off easily.
