I absolutely concur!..........:small3d022:The trailer in entry point #8 of this thread is V-Nosed? I don't know a whole lot about trailers but shouldn't a V-nose trailer be shaped with a V-nose?
Go to this link and scroll across the gallery to picture #7. TC Trecker 5' Wide Gallery - Wells Cargo Corporation
There you will see a red V-nose trailer model # TC581-V which is the exact trailer the OP purchased. The trailer is V-nosed (at least to me) and looks nothing like the trailer on entry point #8 of this thread.
I figured V-nose meant just that... it has a V-nose shape unlike the Flat front of the white trailer from earlier in this thread. Am I wrong?
I have pulled both kinds of trailers and the V-nose used un-mistakenly less fuel at road speeds. To me, the flat front trailer was like pulling a garage door through water at 50 mph.
Bubbies concern... I've found that putting a 6x6 under the bike and pulling it down to secure it puts less strain on the suspension and makes the bike rock solid.
06rdking, your post is the reason why it is so important to have moderators here, to let the story reveal itself and not beat up on the poster. If I had the opportunity to trailer my bike when I did Field Service here in the States, that would have been rightous...now if someone can figure a way to get it across the "pond" internationally that would be even better! :ap
why would you want to make you bike frame become part of the trailer? all these trailers bounce or jar bad when you hit a big pot hole. by ancoring your bike down solidly on a block just sends all that energy stright through your frame , motor, switches, you name it. the bike can be sinched down to be hauled completely safe and still not bottom out the suspention. I know we have hauled alot of bikes all over this country. I have a 21 ft doolittle cargo trailer that is set up to haul 4 big bikes. I have the condor wheel chaucks . And I ran E track down both sides and a strip of E track down the middle . I bolted the E track and the condors through the floor. the floor is 5/8 marine grade plywood. it works flawlessly! by the way do not sinch down your front so far to colaps the front forks and I personaly wont leave them sinched down over night.
If you were coming this way you could borrow my sporty and you wouldnt have to haul yours across the pond
it is the older solid mount engine but it is well suited to our roads and knows most of them pretty well
