1st congratulations on deciding to do your 1,000 mile service chuck60.
On the touring bike if you steer completely right from the left side of bike, you should see the fitting on the steering stem neck on the left side. It is probably a straight fitting and you may want to change to a 90 degree fitting. On my 2008 the fitting is a metric thread.
If no fitting there then consult owners manual and see if there is a service interval for the neck bearings and if not maybe HD has finally gone with sealed bearings...
Just a note that when greasing you are going to use alot of grease on first time for you are completely filling neck cavity....
