IF it is not the Main bearing on the crank?
IT Probably IS the old Original style Compensator...
I too had mine go out but at 50,000 miles. Hard starting and kickbacks when Heat Soaked engine was common...
The reason I say the compensator, IT does USUALLY have a short life on Quite a few bikes. (original used on 07,08,09,10, ? if 12)
Do a few hard takeoffs in first OR hold the front brake on for no forward motion and let clutch IN and OUT at fast idle several times to make things Move in the comp area... Any unusual noised should be noted...
The replacement Modified SE Comps are Many since I did my SE08-A a couple years or less back. My SE08-A replacement comp works just great as MANY didn't in a lot of bikes...
HD IS still changing and working to get it right but Don't Hold Your Breath...:shock
JUST another thought.... Before Loosening the comp, TIGHTEN it to see IF it might be OR was LOOSE...
