Porter
Junior Member
The Harbor Freight model - Harbor Freight Tools - Quality Tools at the Lowest Prices
is the model I bought and use. It has M 8.8 bolts throughout. The welds are very good as is the construction.
The lift lines up (on my 2007 UC, centers of the lift pads) on the rear cross member and the other just forward of the jiffy stand frame mount.
You can get to the oil drain plug with lift but it is easiest if you have the lift enter from the left side of the bike so the bottle jack is out of the way. Then you have to rig up some sort of funnel to catch the oil and direct it to a container.
In the end, I found it easier to leave the bike on the ground to drain the oil. The bike is hot when I change my oil and that adds a little burn risk raising it. Once it is drained, I put the plug back in and then lift the bike after it cools a little. The lift makes it easierto change the filter and check the tires, critical fasteners, exhaust brackets and bolts etc....That's all part of my oil change procedure though. Same thing with the transmission fluid change. I do change the primary oil up on the lift, as the position of the vertical drain plug makes it very easy to collect the old fluid, plus the bike is level when you add the new primary oil (as per the manual).
