On a 2014 Harley-Davidson motorcycle, a red light on the dash typically indicates a serious issue that requires immediate attention, often related to the security system or a problem with the bike's electrical system, and should prompt you to pull over safely and check your owner's manual for specifics on the light's meaning; if it's a flashing red key icon, it usually signifies a security system alert.
Key points about
Does your rear brake light stay on? Check all your light bulbs, could be a burnt out bulb. Also check for a pinched wire when you reassembled your speedo/dash.
Key points about
