"IF" you ever HAVE to use Lower Octane Fuel,,,,, DON'T LUGG the motor.. Especially in warmer weather.. keeping up the RPM above NORMAL cruise will Help engine NOT ping or Knock.. Don't try Fast increases in speed,,, Take time and go at it GENTLY..
Don't FILL the tank all the way with LOW octane,, Use JUST enough to get you home OR to the Next Station that Has the Better high octane fuel.. Then top tank off with the high ...
I have added Diesel/Kerosene at 40/1 to SLOW the fuel burn in low octane so I can use it but with todays bikes with 02 sensors, that is Not a good thing to add to fuel...
