Rydn4fn,what problem are you having with your charging system? Just a bit of background on my original problems ,about a year ago my stator was leaking oil and I was having some intermittent problems,bike would idle high like 2k then when I stopped would return to normal also at times it would idle so low that it would die,but returned to normal when come to a stop.Took it to HD they changed my stator under warranty,but could never dup riding probs,these issues never resurfaced,I suspect the flaky stator was causing them.About 3 months after changing stator my battery stranded me had to trailer bike home wound up buying new battery. all was good for a few months then suddenly batt lite came on volt was 12 and dropping went home did a few checks no output at all from volt reg with 26 vac at stator,changed volt reg now good. The point im making is it seemed as if one thing led to another,a flaky stator takes out batt poss also damaged the reg,but when reg went it went no intermitts like stator and or batt may have given. Good luck Tom..btw your near leakey ever done the loop just got back last month..Awesome..
