Here we go!
Over where i live,it gets plenty hot in summer.Ambient temps.up as high as 38-40 degreesC -and
sometimes more.Reflected road heat of up to 50 degreesC.(AS MEASURED ON MY WORK SITES).We have put full Synthetics into our 3 '08 bikes;H-D oil coolers on each and Lenale Engineering cooling fans on 2 bikes.Plus a Thundermax on one and plans for either a Tmax or TFI on another.
Now i know others on this site have had bad experiences with the above fans;WE haven't.They've worked fine and done their job.Blowing air across the fins.The oil coolers also work well;EVEN if you're not moving.Heat can be lost through convection.and the extra surface area of an oil cooler will allow this to happen.Every BTU lost helps.
Full Synthetic oils are well documented elsewhere on this site,suffice to say we saw about 12 degreesC lower temps.
And better lubrication-what more could you want?
I did not intend The fuel device didn't
seem to make much difference to running temps,but sure as
(EDITED) made a difference to running!The fact that it has altered the lean characteristics of the motor and made it perform better, has more than likely contributed to a cooler engine.Petrol has a latent cooling ability,and if you add more,then you are,in fact, helping to cool.
You do what you can.And you can to
il coolers,altering fuel mixtures,free flowing filters and pipes,fans;and depending how far you want to go,you can alter the timing or bump up the compression ratio.
I know you shouldn't have to do any of this,but doing SOME of this will provide you with a better bike.
