Thanx toolbox I've been working on it as I can. It did sit for awhile I cleaned carb changed fluids and will run couple minutes but plugs start to foul, I changed them and same prob basically clean and repeat....I cleaned carb but can't get small pilot outIf the bike sat for a long time you probably need to pull the carb. and clean it. Could also be a bad vacuum line from carb. to the pet cock. Does it have a security/alarm system on it? Glad you got it started though, even if just for a short time.
tourbox
