Hummm, correct me if I am wrong & please don't take this the wrong way, but weren't you heading out to purchase an ECM when Glider & I stopped you? Not that I need a Gold Star (nor does Glider I am sure) but even the worst actors get mentioned at the end of a bad movie. And it was a movie.
ECM was next, after complete removal of the TFI, which would have fixed it, since the problem was in the TFI wiring harness. I was literally down to wiring harness, TFI, or ECM. There was nothing left to replace. If I had not finally gotten a code, I might still have missed the wiring harness, since the wires had to be moved "just so" to get the injector wire to open.
My intent was not to imply that I did not have help from here. What I intended to convey was that the dealer had no part in the solution, at all, and after serious green having been given to them to fix it. I did my own wrenching, and in teh process, learned most of what is available to know about whatever I touched in the process. Since correcting my issue, I have been doing whatever i can to give back to the site, and its good members.
You can be sure that if I had replaced the ECM, it would not have been the Harley one, that I can't talk to without all the proprietary gizmos. I had been setting aside for a Thundermax. Little by little, HD is losing it's "over the barrel" leverage on me and my scooter. I still may dump the stock ECM for a Thundermax, but as a completely voluntary operation, not trying to correct an issue.
Enjoy,
Rich P
