free website stats program Help! How to remove riser cover for 2009 RK | Page 3 | Harley Davidson Forums
What did you end up finding out?
I'm interested to find out. My 07 has allen screws where your blanks are.
interesting, some import cars use shear bolts on the ignition switches ie tamper proof ;-) usualy move with a punch n hammer or notch it and turn with a screwdriver
Posted via Mobile Device
Here is the results Rob7711 found that Glider put into a Self Help Tip...
http://www.hdtimeline.com/chassis_s...d/21866-road_king_riser_cover.html#post192538
I said in Post #2
Really sad when you have to take a drill to your bike...I hope you will replace that disposable fastener with something descent, like a shouldered trim screw or the like that will "nest" in the relief cavity. Sounds like a trip to the local hardware store is in order if you work on your 2009 RK riser...
Enjoy the new bars, I have them on my 09 RK and love them compared to the stock ones.
Kruppt, just curious...did you run into the problem with the security fasteners Rob had, or did you have the dealer do it? :33:
